Steam valve cleaning
We moved into a new home, and don't know how long it's been since these valves (in the basement, NOT on the radiators) have been cleaned. In order to clean them, do I need to turn the boiler down/off? Do I need to plug the hole during the time the valve is removed?
    ethicalpaul Posts: 8,993
    Just replace it, it's not worth trying to clean it.
    You can just lower your thermostat while you change it.
    I would recommend probably a Gorton #1 which costs like $45 but other people will demand you buy a Gorton #2 which costs $150.
    Jamie Hall Posts: 27,738
    They really shouldn't need cleaning. However, they look a little small if they are the only vents on the main steam lines.
    All that said, if you did want to clean — or relace — them then the boiler has to be off when you are working, as steam will come out the opening!
  • kfloyd
    kfloyd Posts: 4
    Thank you for the advice! I've never heard of Gorton. I need to replace several valves on radiators throughout the house as well, so maybe I should give them a call. For the radiators themselves, would you use Gorton valves or something that has the adjustable dials on them? (1, 2, 3, 4, etc)
    I kind of prefer Maid O Mist for radiators due to the ease of swapping out the various sizes of orifices without having to change the whole vent. Plus they cost only US$14 at supplyhouse.com
    But MoM and Gorton Radiator Vents have the same sizing system so it's quite convenient to swap between them.
    I'm not partial to adjustable vents.
