Using reducer on the 1" Hot/Cold water connection on indirect hot water heater.
yekasi
in Gas Heating
hello.
If a indirect hot water tank comes with both TOP and SIDE domestic water connection with TOP being 1" and Side being 3/4". The house domestic pipe size to and from the existing hot water tank is a 3/4",
Due to this new tank's layout, using the top connection is a bit easier for piping with a corrugated stainless steel pipe - I want to know is it a problem to just use a Brass 1" to 3/4" reducer on the top the heater directly?
The heater in question is this one.
- Use the Hot and Cold 1" outlet, with a reducer to 3/4". Add mixing valve on top and connect to existing 3/4" pipe.
- Cap off the Side 3/4" HOT water pipe opening.
- Add a drain valve to the side 3/4" COLD water pipe opening.
Does this make sense to you?
thanks,
Yep.
Sounds like you've got it. You should be fine.
Thanks.
For the reducer, i found 2 types…
- STainless steel one - https://www.supplyhouse.com/Merit-Brass-K412-1612-T304-1-x-3-4-Stainless-Steel-Reducer-Coupling
- Or This brass one?
https://www.supplyhouse.com/Elkhart-30154-3-4-x-1-Copper-x-Female-Adapter
thank you.
