Low Temperature Thermostat??
I have a pole barn woodworking shop that is fully insulated and drywalled. Have a gas furnace for my heat source. When not being used I turn the thermostat down to 50f which looks to be the lowest setting.
Wondering if there is a lower temperature thermostat available?
Thanks!
  • tcassano87
    tcassano87 Member Posts: 137
    why would you need the thermostat to get lower? Just turn it off
    pecmsg Member Posts: 7,053
    What type of heat?
    hot_rod Member Posts: 27,445
    edited January 24
    that is a typical low setting for wall type thermostats . You could do a search for brands or models that may go lower.
  • ratio
    ratio Member Posts: 4,234
    https://iohvaccontrols.com/product/io-temp-stat/ has a 41° model.
    You may run into issues running that low, however. Check the furnace paperwork for the lowest permissible return air temperature.
    pecmsgbjohnhy
