Lock out on Carlin gas gun
OK, another post about my boiler.
The Carlin gas gun has - within the last 2 weeks - gone into "lock out" mode 3 times. It's easily rectified by pushing the red button, but obviously there's a problem. Before I call a pro, is there anything I should check? Here's a photo, I can provide more if needed.
No advice. I'm ripping out my Carlin fired boiler in part because that damn gun is so unreliable. Goes out of combustion tune at the drop of a hat and it's a bear finding someone able and willing to work on it without charging a small fortune. This fall it was running all sooty and CO spewing.
EDIT: I do have a word of advice, last time mine was locking out in Dec the screen (an upgrade I did) was saying "no flame", so I found a video on how to clean the flame sensor and it solved the problem. But without that diagnostic you're just guessing. But it can't hurt to try! I think this was the one, if not it's the other one by the same guy. Bizarre and lame, with some anti-semitic comments, but it had the info: https://youtu.be/Xk173v28_dQ?si=p3RDmKjJpLmQoK0R
That's an older primary and they have been problematic. We routinely upgrade to the newer one that @HVACNUT mentioned and this solves the problem.
Consulting0 -
Has the most insightful answers. Always.
Brought to you from the National Sarcastic Society
What's your point? I offered my experience with them being unreliable, and a possible solution to the lockout. You didn't, just told him it was his fault it locked out.
No I didn't, just told him it was his fault it locked out. I mentioned that you are an expert on things of this nature. I may have been mistaken. Disregard that post @Dsisson I can be a little goofy from time to time. I do have over 1000 LOLs
You're ripping out the Carlin fired boiler. What do you plan to put in its place?
Heat Pumps! 🤣
- 121 Chimneys & Flues
- 15.8K Strictly Steam
