zone pumps to zone valve conversion.
hot_rod
hot_rod Member Posts: 27,060
Generally the decision to zone with pumps or valves comes down to personal preference, and maybe past experiences.
When you see an installation with a wall of zone pumps, maybe 4 or more, that system is probably over-pumped. 6 zone pumps on an 80K boiler would be an example. All pumps running way to the bottom of their curve with wire to water efficiency below 20% on a common PSC type circulator.
With the acceptance and wide availability of ECM delta P type circulators, the potential to drop considerable power consumption and have better flow control over the zones could be an option.
A backup pump piped in or on the shelf could ease the worry of a single pump causing the entire system to be down.
Siggy had this thought so I built up a prototype.
Thoughts or suggestions?
GGrossHydronicMike
  • GGross
    GGross Member Posts: 1,773
    Was it very tricky to get the same port to port length as the pump or did you get it first try?
  • HydronicMike
    HydronicMike Member Posts: 292
    Pretty cool idea. I did something similar for flushing older systems. I made up a straight pipe with two flanges (connected to iso flanges) to flush the system, initial purge it, then swap out the blanks for circulators. To me I think it's a way to keep junk getting lodged into impellers.
    pump spacers, handy for piping systems for the correct spacing
    , too
    Yeah, it took a few flange brand tries:) This is where BSP threaded pipe shines, Loctite or hemp the threads and stop wherever you want.
    A copper sweat version is pretty easy to get "exact", but the sweat flanges are more$$
  • bjohnhy
    bjohnhy Member Posts: 186
    Where do i put in an order for these?
  • GroundUp
    GroundUp Member Posts: 2,482
    Neat idea and all, but don't we need to repipe anyway to add a system circ?
