Ghost flow help please
can you hear the offending flocheck close when the circ stops? Very often they make a distinctly metallic tap when the weight falls to the seat.
I don't think I've ever heard the sound of a Flo valve seat. I've definitely heard them chatter.
My bet is the same zone gets the ghost flow after the swap. Spring Check on the return, or zone valve as @EBEBRATT-Ed suggested.
This is fun when I'm not there.
We can talk about it forever. A zone valve.
didn't get a chance to swap them today but hopefully tomorrow
3/4" flow checks are too small and problematic with any rise . The lighter weight and smaller seat could be the issue .. A basement zone not a problem .. The 1" flow check would be the safest to install … Next time around
Zone 1 is on the 2nd floor. The pipe has a 55' run in the basement then goes up 2 stories.
2nd pump from the left is new. I replaced it a month or so ago. I do not believe it has an internal Flocheck but could be wrong.
new pump says 007-F5
zones 1,2,3 all rise to second floor. Zone 4 is first floor. Zone 5 is hot water tank
Swapped flow checks or the new pump to the problem zone?
just the flochecks to start with. Want to see if the problem moves.
Did you swap the whole valve, or just the inserts?
