Manufacturer OEM parts
zepfan
zepfan Member Posts: 471
Does anyone know if there is any type of law that equipment manufacturers are required to make replacement parts for their equipment? It seems to me that the time that replacement parts are available is getting less, and less. As an example ECM motor modules(the part that almost always goes bad, when the motor is still ok) is now no longer made by one manufacturer as a replacement part. You have to purchase the entire assembly, the motor, and module. The unit that this out of is only 11 years old. The customer is stuck with either an expensive repair, or a much more expensive complete replacement. Any thoghts would be greatly appreciated. thanks to all
