Empty a bladder type expansion tank.
Before you unscrew it do you have a method to empty it? My back is done with this. Ive read about using a battery powered air compressor to blow it out once the system is isolated and drained. I have though about putting a bucket underneath and driving a hole in it (haven't don that yet)
i assume a bad one? drill a hole in it.
After you get the tank drained and removed install this for future use!
41672 - Webstone 41672 - 1/2" Pro-Pal Full Port Brass Ball Valve w/ Hi-Flow Hose Drain (600 WOG)
2 -
First, if you know the tank is bad, replace it. If you're not sure, what is the date code on the label, serial #? Maybe the air charge is diminished and all the tank needs is a proper air charge. I have had these tanks last 20 years and some have failed in less than 5 years.
If you have no way of isolating the tank, you have to drain down the sys. Do you have anti freeze in the sys? If you are lucky then the installers put isolation valve on each heating loop (probably not). As my Dad use to say,"If I didn't bad luck, I wouldn't have any luck at all". Isolate the zones. If you replace the tank, put a Webstone valve on the tank so it will be much easier to service next time. Use this valve. It's directional so install the right way,
I bought for a modest sum at Home Depot a small 120 Vac tire compressor that I use to put air in these tanks and of course my car tires.
https://www.supplyhouse.com/Webstone-40612-1-2-Threaded-Pro-Pal-Full-Port-Ball-Valve-w-Hose-Drain
120-Volt Corded Electric Inflatorhttps://www.homedepot.com/p/Husky-120-Volt-Corded-Electric-Inflator-HY120/301753174
@mattmia2 , I don't want to work that hard. Dual use.
Regardless if the bladder has failed or you just want to empty an under-charged tank to reset it, compressed air into the air schrader valve will push out the fluid.
Yet another option is a portable air tank like you use for filling tires, about 40 bucks at Harbor Freight.
I'd like to see Milwaukee combine their cordless pump and compressor into one tool. A lever or knob to select one function or the other.
Living the hydronic dream3 -
why break one tool when you can break two…
Oh yes, at least an isolation valve for the tank. I have been installing these. But I do like the larges drain on the one you linked.
I recently picked up the M12 compressor. The size is great, you a small box in the truck
When there's no isolation/drain valve assembly on x-tanks, it can be a huge pain. Removing the schrader valve helps, but with a good bladder, there can be an unexpected weight when released with a potential for lots of water. Maybe someone will come out with one that has a small release valve tapped into the tank itself.
I've got both the cordless Makita and Milwaukee compressors and like the Makita trigger action vs. the push button Milwaukee. Easier to let go of the trigger to stop air flow than pushing a button. Also got the dual presta/schrader fitting for bike tires/x-tanks.
Two btu per sq ft for degree difference for a slab1 -
