Spud Replacement/Thread Damage
I am redoing my bathroom and repainting the radiator/replacing the valve. I had to cut out the old spud and used a hand saw to cut the piece out. Unfortunatly I went a bit deeper than i thought and cut the threads of the radiator slightly. Is this still usable with heavy dope and even tape to seal things up? Is there something I should do differently to allow me to reinstall this radiator?
We have all done that at some point in time. It will probably survive. Put a little dope on the inside threads when you put the new spud in.
Not much pressure there anyhow.
If regular pipe dope doesn't hold, you might have to try an anaerobic sealant.
Hmm. I have used it many times. Can't say that I agree with you.
Try and clean the threads up with a tap. If you don't have a tap try using a nipple to test the threads out. Remove the nipple and use good tape. I like using 3/4" megatape. Just wrap is fairly good and use a good quality dope. Here in the Detroit area the supply houses carry a local company "Give me the Green Stuff" by Jomar. It works on pretty much everything. If that doesn't work Pando works or go old school and string wick. We have all had some oops on threads at some point, i've seen far worse.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
If the radiator threads are visibly cut, heavy dope and tape may not reliably seal it, so you should clean/chase the threads properly or replace the damaged section to avoid leaks rather than trying to force it back together.
Can't replace the radiator. Tapping or chasing the threads will not get rid of the cut section
2 -
yeah…didn't think of that. The smallest you can get is maybe a 16oz. can for under twenty bucks.
You mention wicking. I like that idea. Haven't used wicking much since teflon tape showed up. My thought if not the Expando would be to wick the threads then teflon tape (maybe six wraps) then pipe dope on the teflon.
At least it is on the top side so at worst it will only leak steam instead of water!
One last ditch effort if you have trouble sealing it. Clean the threads using a tap then put some JB-Weld or similar over the cut threads then install a nipple and take it back out. Should leave the cut part of the threads in better shape maybe?
Let it harden and then go nuts again with pipe dope and teflon tape.
I'm not a fan of JB-Weld but if it fills in the gap in the threads it might help seal it.
i'd use permatex before i'd use jb weld. rtv wouldn't' fuse it together permanently.
you can get some cotton string and peel it apart to a single strand to use as ball wicking without having to search out single strand ball wicking.
chase it with a tap
Teflon and neverseize
The one trick I learned in addition to the "tape and dope" is to put a small amount of dope on the inside threads if you have a troublesome joint.
Screwing the fitting in tends to push the dope outside. We have all seen this you remove a fitting and the end of the nipple is bare.
We assembled a CI boiler we installed in a post office which at that time had their own boiler inspectors. 30psi boiler had to hod a 45 psi water test. The Smith 28 boilers had a 6" tapping in the front that we put a 6" plug into it and it leaked.
We took it out and put it back and it still leaked. Then I remembered the inside thread trick. Took it out and doped the inside. No more leak.
Everyone has their own choice of dope and methods. Its all good. You find out what works for you and stick with it……………………unless it goes bad LOL
