Spud Replacement/Thread Damage
Brycewvu
Brycewvu Member Posts: 40
I am redoing my bathroom and repainting the radiator/replacing the valve. I had to cut out the old spud and used a hand saw to cut the piece out. Unfortunatly I went a bit deeper than i thought and cut the threads of the radiator slightly. Is this still usable with heavy dope and even tape to seal things up? Is there something I should do differently to allow me to reinstall this radiator?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,388
    It happens.. Run a tap through to clean the threads ,then use good tape and pipe dope….
    STEAM DOCTORpecmsgGrallert
    EBEBRATT-Ed Member Posts: 19,729
    We have all done that at some point in time. It will probably survive. Put a little dope on the inside threads when you put the new spud in.
    Not much pressure there anyhow.
    Alan (California Radiant) Forbes Member Posts: 4,651
    edited January 7
    If regular pipe dope doesn't hold, you might have to try an anaerobic sealant.
    mattmia2 Member Posts: 15,749
    is that part of the radiator itself or is that a bushing?
    Grallert
  • Intplm.
    Intplm. Member Posts: 2,850
    When a cut thread situation like this occurs, this is an excellent product to use.
    It does what its name says and is made to seal cut threads. Give it a try. It should work for you.
    reggi
  • retiredguy
    retiredguy Member Posts: 1,083
    If that expando does not fix the problem remove the spud and try using RTV silicone. Just make sure in either case that you allow adequate time for the product to dry and set.
    kcopp
  • Intplm.
    Hmm. I have used it many times. Can't say that I agree with you.
    Expando is fine but for a HO to buy a whole can for one joint?
    Plumber buddy of mine always swears by string wicking.
    ethicalpaulCorktown
  • offdutytech
    offdutytech Member Posts: 233
    Try and clean the threads up with a tap. If you don't have a tap try using a nipple to test the threads out. Remove the nipple and use good tape. I like using 3/4" megatape. Just wrap is fairly good and use a good quality dope. Here in the Detroit area the supply houses carry a local company "Give me the Green Stuff" by Jomar. It works on pretty much everything. If that doesn't work Pando works or go old school and string wick. We have all had some oops on threads at some point, i've seen far worse.
    Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
    Corktown
  • pacerob
    pacerob Member Posts: 2
    If the radiator threads are visibly cut, heavy dope and tape may not reliably seal it, so you should clean/chase the threads properly or replace the damaged section to avoid leaks rather than trying to force it back together.
    @pacerob
    Can't replace the radiator. Tapping or chasing the threads will not get rid of the cut section
    STEAM DOCTOR
  • Intplm.
    edited 4:36PM
    yeah…didn't think of that. The smallest you can get is maybe a 16oz. can for under twenty bucks.
    You mention wicking. I like that idea. Haven't used wicking much since teflon tape showed up. My thought if not the Expando would be to wick the threads then teflon tape (maybe six wraps) then pipe dope on the teflon.
    Corktown
  • AdmiralYoda
    AdmiralYoda Member Posts: 745
    At least it is on the top side so at worst it will only leak steam instead of water!
    One last ditch effort if you have trouble sealing it. Clean the threads using a tap then put some JB-Weld or similar over the cut threads then install a nipple and take it back out. Should leave the cut part of the threads in better shape maybe?
    Let it harden and then go nuts again with pipe dope and teflon tape.
    I'm not a fan of JB-Weld but if it fills in the gap in the threads it might help seal it.
