Help with replacing valves on an 1920’s coal burning furnace
hi, I’m new to this kind of thing and don’t know where to turn to considering the age of the furnace. The valves on top of my parents old coal burning furnace are both leaking and I need to figure out how to replace them. I’m in the Pittsburgh, PA area. I’d like to do it myself but if it’s going to involve plumbing work then I know I’ll need professional help with it. Any recommendations would be great.
Mercy. Why do they need replacing? If it's the stem leaking, that can be repacked — although getting the packing nut loose may be rather a job. If it's that they don't shut off, then…
Yeah. You're going to need help.
Thanks for the input folks! I’ll try tightening the nut, if that doesn’t work then most likely I’ll have to just call someone in.
@Hollywogg I would suggest putting some penetrating oil on those nuts a couple of times a day for a few days. If you can shut the boiler down it would be better so the oil doesn't burn off. Then put a wrench on the nut and try to loosen and tighten working it back and forth. If you get it to move snug it up and see if the leak stops. If it doesn't you can back the nut off all the way and add some string packing or get some help.
Now my mouth is watering,
Before you attempt to tighten the packing gland nut please be sure to close the valve for one turn to prevent
damaging the stem.
Are they burning Anthracite Stove Coal or Bituminous stove coal?
You have rocking coal grates in that beautiful Gurney coal boiler.
How many floors in your parents home?
Is there an open to air expansion tank in the attic?
Please take more pictures of the boiler and around the boiler and the stove pipe and air controls on the rear of the boiler.
Please take pictures of the radiators in the home.
Is there an open to air expansion tank in the attic or the third floor? Please take a picture of it and its piping.
- 120 Geothermal
- 396 Solar
