Mystery pipe
magewick
magewick Member Posts: 29
I have a two pipe vapor system that has a 76 vent on the return line to boiler. Also, there is a vertical pipe coming out below the basement ceiling about 8 inches long. It’s the same size dia as the return line to the boiler. I don’t know what it’s for if anything. Please advise.
    mattmia2 Member Posts: 15,984
    we're going to need more information than that. in theory the vent on the return can be just an open pipe.
    109A_5 Member Posts: 3,684
    edited December 2025
    @magewick Pictures maybe? I looked at some of the pictures in some of your other posts, I don't see anything like you describe here.
  • magewick
  • Grallert
    Grallert Member Posts: 1,073
    What's it connected to above?
  • magewick
    unable to find the other end - the pipe is in somewhere in the wall. held a flame to the pipe end while boiler is running - flame is steady - no movement.
    pecmsg Member Posts: 6,878
    that looks like an abandoned pipe. The end was cut with a hacksaw or sawzall
    Big Ed_4pumpcontrolguymattmia2
    You would have to envision were it may have gone to. Like a radiator that was removed, to the 2nd floor or attic, a water pipe left over from a repair or remodel.
