Mystery pipe
I have a two pipe vapor system that has a 76 vent on the return line to boiler. Also, there is a vertical pipe coming out below the basement ceiling about 8 inches long. It’s the same size dia as the return line to the boiler. I don’t know what it’s for if anything. Please advise.
we're going to need more information than that. in theory the vent on the return can be just an open pipe.
What's it connected to above?
unable to find the other end - the pipe is in somewhere in the wall. held a flame to the pipe end while boiler is running - flame is steady - no movement.
You would have to envision were it may have gone to. Like a radiator that was removed, to the 2nd floor or attic, a water pipe left over from a repair or remodel.
One Pipe System0
- 123 Chimneys & Flues
