Williamson GSA-100 Steam Boiler Tappings
So we usually install Burnham Steam Max but trying to save someone a few bucks on install. I’m sure it does but the manual doesn’t show it so want to make sure. Does anyone know if the Williamson GSA-100 has a right side tapping for the return line/equalizer? Was gonna call Williamson tomm but figured I could check here quick
ok perfect thank you, figured it had it. Wanted to make sure before offering the option
perfect good to know thank you, left side outlet is fine for this situation, the right side return is a huge help. Makes things a lot easier
You must have got one, that's been sitting on the shelf for a few years. There was a short period of time where Williamson eliminated the tight hand steam tapping. They reintroduced to the right hand Steam tapping, a few years ago. I just installed a boiler, using the right hand tapping, last week.
@STEAM DOCTOR it had been sitting. it was a scratch and dent. got the casing and firebox bent and dislocated by poor forklift handling in stacking another on top. and it sat until I asked what they had around. no one else wanted to mess with it, but i needed the casing off anyway for placement so a little body work and I saved a grand. I know the second steam tapping has been on again off again.
- 50 Industry Classes
