Carbon monoxide readings from mold
Steve_210
Member Posts: 664
anyone ever see high co readings from mold
There shouldn't be — but it is quite possible that there could be interferences.
Can Mold Cause Carbon Monoxide Poisoning? - Biology Insights
Depending upon your sensor, it may be responding to VOC's and not CO specifically. Also, if you have mold, you could have deteriorated conditions in your combustion equipment that results in CO production. Check each combustion appliance separately to ensure they're operating properly. Measure your indoor Rh% and get it under control.
HTH
- 15.8K Strictly Steam
