Okay to turn off power at circuit breaker, for just a few minutes?
GreenMntnMan
GreenMntnMan Member Posts: 7
We just had to have our very ancient oil furnace replaced. New one seems great, and very quiet. Hooray! We have the oil furnace just as back up for subzero weather, as we also have wood stoves and mini splits (and the oil system was in the house when we moved in 25 years ago). So now my dumb question:
There is an electrical junction box basically connected to the furnace, which has a light switch (power on/off for the furnace) and an outlet. The cover plate on the box does not fit flush (the wiring is too tight), so they attached it with only one screw. I have a box extender I want to put on, but I want to turn off the power to the furnace (and box) first at the circuit breaker. This is okay, yes? The furnace will not be running of course (nor will it have been for a long time).
    Jamie Hall Member Posts: 26,854
    No problem
    pecmsg Member Posts: 6,787
    Not an issue.
    If it is off for a while do not run the heat pump for the same amount of time.
  • GreenMntnMan
    Thank you both, though not sure what "If it is off for a while do not run the heat pump for the same amount of time" means. Only heat pumps we have are for the mini splits and on the hot water heater, all independent of the oil furnace.
    Thanks again.
    if you leave the power off for two hours, power it back up and wait two hours before you try to run the heat pump
    mattmia2 Member Posts: 15,653
    what @pecmsg means is if you turn the power off to the outdoor unit for an extended period in cold temps, let it stay on a couple hours before running it to let the crankcase heater heat the compressor.
    Intplm.
    If that boiler was wired right, the circuit breaker controls the boiler, only the boiler, and nothing but the boiler… so it shouldn't affect any of the other heating units.
    A further thought, though. It's just as well to assume it wasn't, and to use a non-contact voltage tester instead of your fingers to find out if the wires in that box as still alive, in spite of the breaker, before pushing on them…
    Intplm.
