DELETED
philosurfer
Member Posts: 2
Wait a second, that last picture in the photo series. The boiler is off screen to the RIGHT, but that middle pipe, which feeds the hammering radiator, is pitched slight at the joint to the left (you can see it leaning on the bottom pipe). I wonder if I simply raise that up a tad, maybe it would fix water hammer?
Try turning that vent to its slowest setting. Even the slowest setting on a vent rite is pretty fast if i recall, might need to put a slower vent on it.
What vent was on the radiator before?
Also it looks like the dry returns all connect together at the boiler above the water line, that is incorrect and can cause a number of problems but might be sort of ok.
It might indeed. In fact, that might be the whole problem…
- 121 Chimneys & Flues
- 15.8K Strictly Steam
