DELETED
philosurfer
philosurfer Member Posts: 2
edited January 12 in Strictly Steam
    Jamie Hall Member Posts: 26,996
    Try raising BOTH ends of that radiator about an inch and see what happens.
    philosurfer
  • BobC
    BobC Member Posts: 5,551
    I find a 2x4 and a block of wood allow you to gently lever a radiator up without much effort and minimum strain on the old pipes
    Bob
    3PSI gauge
    philosurfer
  • philosurfer
    Wait a second, that last picture in the photo series. The boiler is off screen to the RIGHT, but that middle pipe, which feeds the hammering radiator, is pitched slight at the joint to the left (you can see it leaning on the bottom pipe). I wonder if I simply raise that up a tad, maybe it would fix water hammer?
    mattmia2 Member Posts: 15,984
    Try turning that vent to its slowest setting. Even the slowest setting on a vent rite is pretty fast if i recall, might need to put a slower vent on it.
    What vent was on the radiator before?
    Also it looks like the dry returns all connect together at the boiler above the water line, that is incorrect and can cause a number of problems but might be sort of ok.
    It might indeed. In fact, that might be the whole problem…
