Switching main vent from Gorton no.1 to no.2 (edited, updated new info) (edit with plan)
No it's not at all bad, except for your shirt!
I mean keep an eye out for leaks from the vents themselves (the same hole that lets air out). One failure that can happen is the vent won't seal closed against steam. That's the thing to watch out for. Steam is invisible but when it hits the air you can sometimes see the little clouds of condensate, like a teakettle makes
I'd really like to hear if the additional venting has greatly improved the uniformity of heating throughout.
Notice any fuel usage change (i.e., changes in overall efficiency)?
Thanks!
- 120 Geothermal
