Cleaning my Woodshop furnace
Cyclist77
Cyclist77 Member Posts: 246
I Would like to do a though cleaning of my f/a furnace in my shop. I do have a dust collection system but still have airborne wood dust. Wondering how to best clean the heat exchanger? Was thinking to use a leaf blower blowing up through the return air and capture everything that makes it out wit a shop vac. There is no ductwork as it just has a supply that "dumps" heat into the shop.
So thoughts?
    pecmsg Member Posts: 6,893
    forced air woodworking
    Take it apart and wash it !
    hot_rod Member Posts: 27,080
    do you have a good filter on it, change it regularly?
    I would say a blast from the blower or air hose would be an option
    Is performance dropping iff?
    EBEBRATT-Ed Member Posts: 19,891
    I would be more concerned with wood dust in the burners and controls and inducer (fire side) rather than the air side. Remove the burners and blow them out. Clean inducer.
    If it has been a while I would probably pull out the blower assembly and then vacuum and blow out with air.
    hot_rod
  • Cyclist77
    Thanks ! I think a total disassembly is the route I will go.
