DC-GCVC960603BN Direct Comfort by Goodman blowing backwards
shingabiss
shingabiss Member Posts: 1
Warm air coming out of cold air return, registers sucking in air.
  • Ironman
    Ironman Member Posts: 7,918
    Furnace installed backwards?
    If the blower motor were turning backwards, there would be very little air movement, but it would still be in the right direction.
    Bob Boan
    GGrossChrisJmattmia2
    EBEBRATT-Ed Member Posts: 20,374
    I went to start up a roof top unit where the sheet metal contractor was just "finishing up". This was a side discharge no roof curb. He had reversed the ductwork.
    The ductwork had already been insulated on the exterior with mastic and everything.
    He asked me if I could "reverse the fan".
    They needed the unit it was hot out so we ran it a day or two the way it was until sheet metal got fixed. an expensive mistake.
    HVACNUT Member Posts: 7,506
    Is it a new furnace? If it has an ECM blower motor, it should learn rotation.
  • ChrisJ
    ChrisJ Member Posts: 17,480
    @Ironman is right, centrifugal blowers literally cannot blow backwards. They might not work as good, and might be loud in the wrong direction, but it'll still blow outwards.
  • GGross
    GGross Member Posts: 1,940
    According to Goodman you have a downflow furnace, so if you are using this in an upflow application you have the wrong furnace. If so check with Goodman to see if you can swap it to an upflow, some manufacturers let you do that, many do not.
    https://www.goodmanmfg.com/products/gas-furnaces/90-afue-gas-furnaces/96-afue-gcvc96?bvstate=pg:2/ct:r
