Can of worms
Anyone think i might be able to fine a washer maybe packing washer or stem for this valve? I don't want to try to remove the valve. It 100 years old. If something should break where it connects i am in deep do do. I am going to have to drain down the system to replace a gauge. the packing nut can be removed.
I just might go for it. Ill soak it with some PB blaster for a few days. Thanks
You could try opening it then getting some Teflon tape, twirl it up, pack it in, tighten everything back up, and see if it stops leaking. Not sure what’s wrong looking at the picture but maybe that will work.
Daniel0 -
my guess the bib. when that first started tighing the packing nut did help
where is it leaking, is it leaking from the packing or the spout?
sometimes the path to the experience to replace it is rebuilding a few first.
you could also just put a hose thread cap on it if it is leaking from the spout. you can put a cap on it and deal with it when the heating season is over.
………..and don't forget to turn off the water before you start work.
When I worked on an irrigation crew in Oregon on a grass seed farm in the 80's, insects would get into the sprinkler orifices seeking water when the sprinklers were off. When we turned the sprinklers on, the orifice clogged and because of tight scheduling, we couldn't turn the water off and had to change out the orifice live. We got wet, but typically, it was 100 degrees and it felt good.
it is leaking from around the stem
Hit it with PB blaster a few times a day for a few days and it came out like it wanted to! Thanks for the help everyone.
