Can of worms
scatgo
scatgo Member Posts: 75
edited November 2025 in THE MAIN WALL
Anyone think i might be able to fine a washer maybe packing washer or stem for this valve? I don't want to try to remove the valve. It 100 years old. If something should break where it connects i am in deep do do. I am going to have to drain down the system to replace a gauge. the packing nut can be removed.
  • mikedo
    mikedo Member Posts: 301
    just change it hold back on fitting and you shoud be fine
    scatgoAlan (California Radiant) Forbes
    hot_rod Member Posts: 27,495
    Why? A brass valve usually comes out of a galvanized tee easily.
    The stem looks pretty chewed, I doubt you will find a replacement without taking it out and shopping.
    Washer and also the seats go bad, not all seats are replaceable.
    scatgo
  • scatgo
    I just might go for it. Ill soak it with some PB blaster for a few days. Thanks
    mattmia2 Member Posts: 16,875
    do you need the bib washer or the packing washer? the bib washer should be a standard size, the packing washer can be replaced with string packing. that boiler drain doesn't appear to be all that old relatively speaking.
    scatgo
    pecmsg Member Posts: 7,079
    2) 8 or 10” Pipe Wrench’s
    Lyle {pheloa} Carter
  • DanielDAY
    DanielDAY Member Posts: 42
    You could try opening it then getting some Teflon tape, twirl it up, pack it in, tighten everything back up, and see if it stops leaking. Not sure what’s wrong looking at the picture but maybe that will work.
    Daniel
  • scatgo
    my guess the bib. when that first started tighing the packing nut did help
    where is it leaking, is it leaking from the packing or the spout?
  • ScottSecor
    ScottSecor Member Posts: 1,036
    Do not waste your time trying to rebuild. It will come right out. As others have suggested, use two wrenches. Have new drain cock prepped and ready to install.
    mattmia2hot_rod
    sometimes the path to the experience to replace it is rebuilding a few first.
    you could also just put a hose thread cap on it if it is leaking from the spout. you can put a cap on it and deal with it when the heating season is over.
  • ………..and don't forget to turn off the water before you start work.
    When I worked on an irrigation crew in Oregon on a grass seed farm in the 80's, insects would get into the sprinkler orifices seeking water when the sprinklers were off. When we turned the sprinklers on, the orifice clogged and because of tight scheduling, we couldn't turn the water off and had to change out the orifice live. We got wet, but typically, it was 100 degrees and it felt good.
    if tightening the packing nut didn't stop that leak, while holding the valve closed, back off the packing nut, shove an inch to a couple inches of string packing in there and tighten it back down.
    scatgo
  • Pumpguy
    Pumpguy Member Posts: 801
    Ace Hardware #40209 GRAPHITE PACKING is a good choice for this application.
    scatgo
  • Intplm.
    Intplm. Member Posts: 3,031
    The stem appears damaged, and it's missing its handle. Replace it with one of these quarter-turn boiler drains. Doing so will eliminate any questions and future headaches.
    hot_rodscatgo
  • scatgo
    Hit it with PB blaster a few times a day for a few days and it came out like it wanted to! Thanks for the help everyone.
