Radiator Fitting
OldSchoolHVAC
Member Posts: 15
Does anyone know where I could get one of these in 1-1/2"? I found a Watts one but the largest size available is 1-1/4.
Thank you in advance.
Try FW Webb.
Bob Boan
Thank you Ironman!
That would be a monster radiator that would need 1.5" worth of flow.
Or an 11/2 street 90, a union, and a close nipple if there is room, as these fittings are more readily available.
I looked in my stock, have 6 threaded 1-1/4 radiator els. Usually had a couple 1-1/2" but all gone. As others said, probably best just to install a valve in its place as they are readily available.
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
