Radiator Fitting
Does anyone know where I could get one of these in 1-1/2"? I found a Watts one but the largest size available is 1-1/4.
Thank you in advance.
  • Ironman
    Ironman Member Posts: 7,900
    Try FW Webb.
    Bob Boan
  • OldSchoolHVAC
    OldSchoolHVAC Member Posts: 15
    Thank you Ironman!
    mattmia2 Member Posts: 16,428
    That would be a monster radiator that would need 1.5" worth of flow.
  • JUGHNE
    JUGHNE Member Posts: 11,547
    edited November 2025
    It might be easiest to just get another 1 1/2" valve to do the job in the place of the 90 ell.
    We assume that this is hot water…..not steam?
    Big Ed_4Ironman
  • Intplm.
    Intplm. Member Posts: 2,988
    Or an 11/2 street 90, a union, and a close nipple if there is room, as these fittings are more readily available.
  • tim smith
    tim smith Member Posts: 2,928
    I looked in my stock, have 6 threaded 1-1/4 radiator els. Usually had a couple 1-1/2" but all gone. As others said, probably best just to install a valve in its place as they are readily available.
