Steam boiler gauge needed
DHome23
DHome23 Member Posts: 6
Hi all, can someone please opine to see if this low pressure gauge is suitable for a gas fired steam boiler?
https://www.supplyhouse.com/Bluefin-GLP25-5-BM-2-5-Steel-Low-Pressure-Gauge-Bottom-Mount-w-Brass-Internals-0-5-PSI
if not, could you please recommend a site that i can purchase from?
ive looked at the forum and it was stated that Marsh Instruments or from Dwyer Instruments but they dont seem to sell direct retail.
Thanks in advance
  • Big Ed_4
    Big Ed_4 Member Posts: 3,509
    It will work but is the pressure increases above 5# the gauge is toast ..
  • DHome23
    Thank you. Do you have an alternate suggestion you can send my way?
    Jamie Hall Member Posts: 27,223
    Well, yes. But… if the pressure goes over 3 psig you have other problems to cope with before that one.
  • leonz
    leonz Member Posts: 1,799
    edited November 2025
    A low pressure steam gauge from either Dwyer Instruments or Marsh Instruments is what you should have as they are American made pressure gauges.
    ethicalpaul Member Posts: 8,633
    That one from Supplyhouse is fine. I have cheap ones from Amazon that are also fine. This isn't rocket science, it's a little steam pressure.
    I am pretty sure you can get Dwyer stuff direct from them. I get mine Dwyer stuff from eBay where the low price is worth the risk of getting damaged ones. Dwyer stuff is very well built and survives even bad treatment.
