Capping off a riser?
Bathgate
Bathgate Member Posts: 5
I am going on my 2nd year of a steam leak that i have not been able to locate, although I believe it is under the floor on the second story.
I want to put in a shutoff valve in the basement where the riser goes upstairs.
I don't have the means to rip up the floor at this time and that floor isn't being used.
Would this be an abnormal request to make to a contractor?
    Jamie Hall Member Posts: 27,328
    edited October 2025
    No…not really. But. Not every plumber is going to have the necessary tools nor experience to be able to do it! A lot of plumbers — who do a very good job, don't get me wrong here! — tend to turn pale and run when they see iron pipe or have to contemplate threading something!
    Two cautions — which they should be aware of but may not be — make sure the valve you install is "full port" — that is, when it is open, the passage is straight through and the same inner diameter as the pipe. And ball valves are vastly preferable to gate vavles…
    Edit — and one more — make sure that the riser is held at as close to exactly the same elevation as it was before!
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Can you post a picture of the main tee, take off piping etc?
  • Bathgate
    edited November 2025
    Thank you for your comments. I will try to get some pictures added this week.
    Maybe I should look for steam furnace contractor instead of a plumber?
    I would probably start with the company who currently does our annual boiler maintenance.
    mattmia2 Member Posts: 16,693
    Where are you located? We may know of steam contractors in your area. Might make more sense to find a good steam contractor and ask them to find the leak.
    ethicalpaul Member Posts: 8,752
    one of my "clients" had a plumber do this for a similar purpose and the plumber did a great job with some kind of press fitting that he put on the steel pipe, with a full-port ball valve to close off the supply. It was a big one, too, I think 2-1/2"
    megapress can do it. probably better to do it with threaded fittings if you can.
