What the heck is this? This
I was told this is a one-pipe system.
Thanks for the replies. Pretty sure this is on a one pipe system. What would replace this today?
What is it doing? How is it hooked up? There are many options depending on what its function is.
unless that is something different, usually "boiler return traps" just let some steam in to the returns to equalize the pressure to let the water back in to the boiler.
Maybe the building was once served by district steam?
Consulting0 -
Maybe but didn't most district steam systems dump the condensate??
You'd still need to stop the steam from leaving the system before it condensed.
Consulting0 -
True, But you wouldn't do that with a "master trap" the radiation or equipment should have its own trap.
If it's a one-pipe system, the only locations for a trap would be the drips from the steam mains, and they would have to handle the load of all the radiation on their mains- same as if you were using a boiler-feed pump. This is not master-trapping.
Consulting0
- 15.8K Strictly Steam
