What the heck is this? This
I was told this is a one-pipe system.
    Jamie Hall Member Posts: 26,809
    my bet is going to be some old form of F&T trap. Which probably doesn't work any more…
    EBEBRATT-Ed Member Posts: 19,500
    Alternating boiler return trap or "canned ham" Vapor system used to pump condensate back to the boiler with steam pressure.
    Intplm.mattmia2HydronicolicHowardLong
  • pumpcontrolguy
    pumpcontrolguy Member Posts: 12
    Definitely a steam trap of some sort. I'm enjoying the fact that it's got a gauge glass on top to see how backed up the condensate is.
    Hydronicolic
    mattmia2 Member Posts: 15,517
    edited October 29
    the gauge glass is what makes me lean toward boiler return trap vs just an ordinary steam trap.
    what kind of trim is on the radiators?
    Hydronicolic
  • Intplm.
    Intplm. Member Posts: 2,818
    Possibly an older version of one of these? A pump trap.
    Hydronicolic
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,684
    Boiler return trap
    Retired and loving it.
    Hydronicolic
  • retiredguy
    retiredguy Member Posts: 1,081
    It is a steam tap made by Empire Trap company. I saw a lot of Empire traps on very old systems. A lot of them were bucket traps but this one could be an F&T. You would have to open it up to find out.
    Hydronicolic
  • Hydronicolic
    Hydronicolic Member Posts: 18
    Thanks for the replies. Pretty sure this is on a one pipe system. What would replace this today?
    What is it doing? How is it hooked up? There are many options depending on what its function is.
    edited October 30
    Unusual to see that on 1 pipe steam. Don't know how that would work. Several companies make pumping traps. Most of the larger trap manufacturers make pumping traps. $$$$.
    Its only function is to pump condensate back to the boiler
    New England SteamWorks
    unless that is something different, usually "boiler return traps" just let some steam in to the returns to equalize the pressure to let the water back in to the boiler.
    Steamhead Member Posts: 18,187
    Maybe the building was once served by district steam?
    Consulting
    Maybe but didn't most district steam systems dump the condensate??
    You'd still need to stop the steam from leaving the system before it condensed.
    Consulting
    True, But you wouldn't do that with a "master trap" the radiation or equipment should have its own trap.
    If it's a one-pipe system, the only locations for a trap would be the drips from the steam mains, and they would have to handle the load of all the radiation on their mains- same as if you were using a boiler-feed pump. This is not master-trapping.
    Consulting
