Does any company make slip tees in propress/copper press standard?
archibald tuttle
archibald tuttle Member Posts: 1,199
edited October 2025 in THE MAIN WALL
you can get slip tees in sharkbite and other 'slip-on' coupling styles but i can't find anyone who has them for press application. that seems pretty silly. you can get slip couplings pretty readily but i am constantly wanting slip tees. veiga doesn't even have the word slip in their catalogue. maybe they call it something else?
this will be my AHRExpo bugbear for the booths if I can't come up with something that is already available.
thanks, brian
    pecmsg Member Posts: 7,043
    they make them
    EBEBRATT-Ed Member Posts: 20,155
    I have only seen couplings
    kcopp
    hot_rod Member Posts: 27,416
    mattmia2 Member Posts: 16,692
    the couplings are called "no stop" instead of "slip" so maybe try that
    Grallert
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    They list the slip coupling a repair coupling . Slip tee would be cool …
    I like Veiga , Its a much tighter connection. I can tell when I catch a off brand in my stock ..
  • archibald tuttle
    edited October 2025
    @mattmia2 don't stop. can't remember what raunchy controversial movie that was from but i'll now forever recall it when I need a slip fitting. @pecmsg if you have actually seen or seen a listing for the fleeting no-stop tee and have a brand, part number, distributor or any of the above, much appreciated.
    i have space to do this with a regular tee a nipple of copper pipe and a slip coupling, but I am forever looking for slip tees so even though I have a workaround for this project, would love to chase this down. thanks. brian
    there site is tough to navigate. Check with the supply house in the AM
    https://www.supplyhouse.com/sh/control/search/~SEARCH_STRING=Pro%20Press%20Slip%20Coupling
  • archibald tuttle
    @pecmsg i can find the slip couplings, i can't find slip tees. maybe my initial post wasn't clear on that. brian
    I know on most sweat copper couplings or tees you can file out the stop and slide it up the tube.
    I don’t think the hub design of typical press fitting allows that?
    i was wondering the same thing. also with a sweat fitting you tend to fill in where you filed away with solder
