Utica Hot water boiler Model UH15B096FE
stevenknaub
stevenknaub Member Posts: 36
is it acceptable for the top and Draft Side access panels on this boiler to have large gaps?
Concern is that flue gases may be leaking through these gaps into the home.
    pecmsg Member Posts: 7,043
    All homes should have at least 1 if not more low level CO Detector(s).
    Big Ed_4
  • bburd
    bburd Member Posts: 1,303
    The boiler block, breeching and draft hood contain the flue gases. The access panels have nothing to do with it, they merely cover the insulation over the block.
    Flue gases may spill from the draft hood or burner opening in abnormal draft conditions, so a good carbon monoxide detector in the boiler room is essential.
    Bburd
  • stevenknaub
    thanks for your assistance!
    Blessings through Jesus Christ our Creator
