New Thermostat
HotRod1975
Member Posts: 17
purchased this today to replace old mercury therm. I plugged in the R & W set the anticipator inside to .6 as the manual on boiler says and boiler won’t kick on. Do I need to remove the red plastic cap on the back??? Am I doing something wrong?
manual says nothing about that part.
Replaced it because a tech said it’s the reason for short cycling on system
And no, leave the red cap alone.
IIRC there'sa cardboard cover over the contacts under the cover. That does get removed if it's there.
Do post a pic of it inspire installed with the wiring.
is that lever on the pivot a pendulum for leveling it when you munt it from when they were mercury?
- 117 Geothermal
