Drilling into metal firebox or not
junta
junta Member Posts: 13
I want to install a top damper on my chimney. I have a metal firebox though and all instructions show drilling into the masonry to install the bracket for the cable handle. It feels like not a good idea to drill into the metal to attach the bracket needed or should I install it on the brick on the edge of the fireplace?
    EBEBRATT-Ed Member Posts: 20,037
    Probably shouldn't drill the firebox even though it could be sealed and the screws will cover the holes probably not a good idea.
    Jamie Hall Member Posts: 27,183
    Drill into the brick. It would be very hard to seal a hole in the metal firebox, and you really don't want flame and combustion gas to get in back around it…
