Can I use 1" black pipe for a 10' runout (couterflow) supplying 1 small radiator?
stormbytes
stormbytes Member Posts: 36
Need to run several short branches to individual rads on the 1FL. Runouts will have good pitch and span < 10' before a swing joint and short riser. Want to confirm I can use 1" diameter black pipe for these short runs. Rads are all < 25 EDR. Book says I'm good for up to 28 EDR.
