Some Steamers
EzzyT
EzzyT Member Posts: 1,377
Both of old failed boilers where way oversized.
IMG_2165.jpeg IMG_2433.jpeg IMG_2434.jpeg IMG_2476.jpeg IMG_2475.jpeg IMG_2477.jpeg
E-Travis Mechanical LLC
Etravismechanical@gmail.com
201-887-8856
Alan (California Radiant) ForbesPaul S_3Ironmanmattmia2PC7060HeatingHelp.com
    Steamhead Member Posts: 18,001
    Looks good, as usual. Question- what are you using the green Taco relays for?
    Consulting
    109A_5 Member Posts: 2,875
    I suspect an easy interface for smart thermostat provision and /or actual installation.
  • EzzyT
    @Steamhead We are using them for smart thermostats interface as @109A_5 has mentioned.
    201-887-8856
    Oh, OK- didn't know those had a C terminal.
    Consulting
    mattmia2 Member Posts: 14,340
    I think half the battle here is showing up with a truck full of fittings and most installers seem to lose that part.
  • dandub1960
    dandub1960 Member Posts: 20
    Looks great. I like how you managed to move the left steam connection of the Williamson with an extra elbow. I may copy that.
    Also were you tempted to install the Bermuda backwards to put the drafthood (and exhaust vent) toward the chimney?
