New Boiler recomendation
Hi, New home owner , oil boiler, baseboard water heating + hot water tank, 2500sqft, Boston., Looking to replace our leaking 40 year old burnham v7, here are some of the options got from installers. Please help to decide.
Weil McLain gold S4
Burnham 206en-to
+3K
Williamson OWB-4
purepro P5
Buderus G115
+8K
Energy Kinetics System 2000 Model EK-1
Is this steam or hot water? And — most important — have you checked to ensure that the possible replacement boiler is the correct size for your house and your system? It's a simple check — for steam, what is the power capacity (EDR) of the installed radiation; for a house a simple heat loss calculation.
Don't assume that the existing boiler is the right size…
hot water, going to ask the installer to check a heat loss calc. thanks
If i might add the Ek-1 frontier can be fired at 4 different firing rates. Great option if you're planning on renovating or adding square footage. Also, the savings in the long run can't be beat. Especially if your making hot water with our storage tank and plate heat exchanger.
If you want to message me i can possibly help with the sizing.
My 2 cents.
Robert W.
Energy Kinetics
EK-1 Frontier no question. That's not a Buderus model. G115 or G215 (you don't need a G215).
Yes its G115 , is that a good?
gas or oil?
Oil
- 116 Geothermal
