Preferred gauge glass cutter
RayWohlfarth
RayWohlfarth Member Posts: 1,824
Just curious what your preferred gauge glass cutter is.I use this one but see other ones on the market that are smaller.
Ray Wohlfarth
Boiler Lessons
Mad Dog_2
  • ratio
    ratio Member Posts: 4,125
    edited October 2
    I use one of these: https://www.supplyhouse.com/Wal-rich-1801006-1-4-Turn-Gauge-Glass-Cutter, works fine. I tried one of these: https://www.supplyhouse.com/Wal-rich-1801000-Tong-Type-Guage-Glass-Cutter, but it can't cut over 7", so I had to send it back.
  • Intplm.
    Intplm. Member Posts: 2,730
    That's a nice one. I'm not sure when to squeeze the handle together after etching. Every once in a while, the glass cracks.
    EBEBRATT-Ed Member Posts: 18,598
    Cutting gauge glass is always hit or miss. Better bring extras is all I can say. I always thought the one pictured was for cutting porcelain insulators.
    never liked the tong type but that's what I had for many years.
    The WalRich 1801006 is what I have now.
    mattmia2 Member Posts: 14,239
    shouldn't tubing break cleanly if you nick it with a file then bend it away at the nick?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,329
    Nolo Contendre Ray...that's the easiest and fastest one that I have found. Rex Wheeler...I call it my mini snap cutter. Mad Dog
  • ChrisJ
    ChrisJ Member Posts: 16,927
    The way I did my last one was I cut it and it ended up a hair too long. I used the same cutter @EBEBRATT-Ed has.
    I then used a belt sander to remove a decent amount, maybe 1/8". It sands down clean and fast, but probably isn't the best thing for the belt.
  • RayWohlfarth
    The first time I did one, I was a first year apprentice. The journeyman said to use a file. I broke two of them before he pulled out the gauge glass cutter. He said he was trying to show the old timers ways.LOL
    Ray Wohlfarth
    Boiler Lessons
    ethicalpaul Member Posts: 7,803
    GGross
  • Big Ed_4
    Big Ed_4 Member Posts: 3,274
    edited October 3
    I had them all , I comfortable for ,at least for 25 years with the "W" shape one .. Yes just a small cut , like a file and just snap.. I had the snap ring type for awhile. The snap ring type is vary good for cutting porcelain. I used that type back in the day with the old different models in the field . I started with the one that scored the inside ..Works better on the outside …
    If I go back into the job with one stick , I get a bad break..I must be cursed :)
    @Big Ed_4
    Thia is the way it works for me. Bring a spare glass and you won't need it the first cut will be good. Don' t bring a spare and the first one will shatter.
    Intplm.Big Ed_4Robert_H
    the file probably works better on long lengths than on trying to cut an inch off an already cut length. there is always a diamond blade on a grinder or even a dremel.
  • Intplm.
    I have had some better luck with this one, but I can't say why.
  • Big Ed_4
    Agree 1" you will break a few . I would score a few points around and tap , let the crack find its way around…
    hot_rod Member Posts: 25,703
    I’ve been cutting the larger glass tube, up to 1-1/4” for my display wall with a diamond wheel in a 4-1/2” angle grinder.
    Hold the tube tightly in a wood block or some jig.
    A small bench belt sander to clean up the sharp edge
    The tube I buy online has the ends flame polished, I have not tried that method
    Glass blowers use a flame to smooth the ends and edges.
    we played with glass tubing in high school chemistry. fire polishing it is really easy, just heat the end of it with a torch. we used a bunsen burner but a propane torch will work too.
