Paint on black iron?
seized123
seized123 Member Posts: 481
edited October 2025 in THE MAIN WALL
Does anyone paint black iron pipes to deter surface rust? If so, with what? I thought maybe Rustoleum high heat spray.
This would be for near boiler piping, and I would tape off the threads so as not to paint them. Just thought it would look better than eventual surface rust.
    Jamie Hall Member Posts: 26,997
    Lipstick on a pig? And since you are going to insulate them, I hope why paint at all?
    ChrisJkcopp
    mattmia2 Member Posts: 15,985
    There is some sort of a tar paint that @Mad Dog_2 likes
    EBEBRATT-Ed Member Posts: 19,881
    You can paint them with Rustoleum. The pipe comes from the factory with sort of a protective coating that tends to burn off when the pipe is used on steam.
    pecmsg Member Posts: 6,878
    edited October 2025
    clean the pipe
    wire brush off any rust
    Then you can paint it
    Is it worth all the trouble……. No
  • seized123
    Thanks for the comments. @Jamie Hall I didn't think of that and I have a lot of insulation I need to do. @pecmsg yeah, probably not worth trouble. Almost everything is copper anyway.
