Oil Water Heater for Disabled Couple on Long Island
Hi, I am trying to help a disabled elderly couple on Long Island in Nassau County. Their oil based water heater has failed and they need it replaced asap. Is there a good yet fairly price plumber who could help them asap?
Try "Find a Contractor" tab on this site. ASAP is likely to be a bit pricey, though…
oil and long island also are likely to be. perhaps there are some state/county/city assistance programs.
I will do what I can to help you sir. Please call me 516 322 2881. Mad Dog
5 -
LIHEAP, in cooperation with a local/county assistance usually will do it.
Oil Heat Cares?
Consulting1 -
Thank you, I called them and they approve work by referral only, if the contractor is affiliated with them.
Is the couple buying their oil from a reputable heating oil company, or C.O.D.?
Retired and loving it.0 -
COD, mostly because HEAP covers the cost and COD is cheaper.
I understand. Unfortunately, Oil Heat Cares works only through full-service oil dealers.
Last I asked them, you can only apply when the season starts and water heaters are not covered, only what heats the home. Did they misinform me?
I agree an electric WH may be the best choice here as long as they have the power available.
would cost far less to install, @ 40gallon would be more than enough for two people, less service too.
