question about upgrading Smith Gates Thermostat
I have the same Smith Gates Thermostat and I am also wondering if there is something out there that replaces this the most with WiFi capabilities?
How 'bout a pic or two, including one with the cover removed?
I just found this at supplyhouse.com: https://www.supplyhouse.com/Mysa-MYSA-IN-FLOOR-V1-0-Mysa-Smart-Thermostat-for-Electric-In-Floor-Heating.
No experience with it.
Can yo provide the model number of that thermostat? I can't be sure, but from the description it sounds as though you have in-floor electric radiant heat, and the thermostat is turning that on and off — though it is possible that the thermostat is actually modulating the power to the floor elements, based on temperature.
That lead going somewhere into the floor may not be a thermocouple lead. It may also be a capillary tube, with a switch in the thermostat itself.
But all that said, we need the exact model number of the thermostat…
- 50 Industry Classes
