kenmore side by side refrigerator/Freezer
I have a kenmore side by side refrigerator freezer
freezer works fine holds temperature
refrigerator does not
found duct or tube feeding refrigerator frosted shut-dethawed it-good airflow as long as freezer door open -no air flow when freezer door shut? could evap fan be weak>its located in freezer and when i remove panel its running
    pecmsg Member Posts: 6,891
    there are one or two return ports from the refrigerator to the freeze that are also frosted closed.
    mattmia2 Member Posts: 16,021
    is the defrost heater good? is the defrost timer advancing properly? how old is this? does it use a mechanical defrost timer or is it electronic controls?
    EBEBRATT-Ed Member Posts: 19,891
    Check the supply and return ducts from the freezer. It also could be the defrost timer or thermostat. The defrost timer and stat are usually relatively inexpensive parts so best to change both.
    PC7060
    is the evaporator frozen up or just frost in the ductwork?
  • creger.robert
    creger.robert Member Posts: 108
    frost on bottom of evaporator thats it coil not frosted
    Bad door gasket or the door was left open for a long time
    Is it a whirlpool or is it after sears got cheaper? Some manufacturers had issues with full defrosting all the drains and such under certain conditions during the defrost cycle and usually had a retrofit kit to help heat those parts better.
  • creger.robert
    it is a old kenmore unit
    but who made it for sears? the source code, the first 3 digits of the model number will tell you. whirlpool is if i remember 110, 106, and a couple others.
  • creger.robert
    106
