kenmore side by side refrigerator/Freezer
I have a kenmore side by side refrigerator freezer
freezer works fine holds temperature
refrigerator does not
found duct or tube feeding refrigerator frosted shut-dethawed it-good airflow as long as freezer door open -no air flow when freezer door shut? could evap fan be weak>its located in freezer and when i remove panel its running
there are one or two return ports from the refrigerator to the freeze that are also frosted closed.
is the defrost heater good? is the defrost timer advancing properly? how old is this? does it use a mechanical defrost timer or is it electronic controls?
frost on bottom of evaporator thats it coil not frosted
Bad door gasket or the door was left open for a long time
Is it a whirlpool or is it after sears got cheaper? Some manufacturers had issues with full defrosting all the drains and such under certain conditions during the defrost cycle and usually had a retrofit kit to help heat those parts better.
it is a old kenmore unit
but who made it for sears? the source code, the first 3 digits of the model number will tell you. whirlpool is if i remember 110, 106, and a couple others.
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
