Any plumbers good at small bathroom layout?
I’ve got a small bathroom, little apartment, pulled out a clawfoot tub and trying to modernize a little bit. Would really prefer not to do a wall hung lavatory. Pedestal is preferred. But something is going to overhang something it seems
Let me know your thoughts!
this pedestal is nice and tall, just gonna overhang the toilet and bathtub
@GW I understand you not wanting a wall-hung lav. I'm not a big fan of them either. The exception when having a small bathroom is this little lav. pictured here. Kitty cornered and very small. They take up very little space while leaving room for proper tub and toilet clearances. Depending on your bathroom layout, this fixture may help you with building a usable and code-compliant bathroom.
How big is the space, "small" is a very relative term. I was in a hotel with a 3x5 shower, toilet and sink.
Curbless shower with a curtain instead of glass can also free up a bit of circulation space.
Does it have to be a tub? Sometimes you can re-think the design with a small shower and still get more room to turn around without bumping into stuff.
I have seen this shower door for a 38x38 shower. The grandkids called that bathroom shower the rocket ship, if I recall correctly.
2 -
Kaos, The video link shows the exact dimensions. Roughly 5 x 5
@Intplm. long story but I wish to keep the wc on the left. There's some old 4x4 brace for the old joists (I elected to keep it, it only helps) in my way if i move the wc. But I could stick my head in the crawl and see if I can make it happen. Good idea.
@EdTheHeaterMan I did buy the tub and had it delivered. I guess I could return it (still in the crate). Good idea. I am generally a tub/shower man when ever possible.
@hot_rod yes that does seem compact. And, my wife too; this is just an apartment.
It was the last 'old school plumbing in the 100plus yo building.
A pedestal sink is more fashionable but the storage under a vanity can be very useful in a tiny bathroom. Does code require a tub? Certain clearances are required to the toilet. I have seen a few bathrooms shoved in closets with a sink the size of a drinking fountain. The European and Japanese brands will have more options.
@mattmia2 no it can be a shower. It’s a small apartment- small everything. I was trying to keep the bathroom, the same exact layout, but the was a couple skinnier than the new Kohler villager. I could put the old clawfoot back in, but that brings several new challenges.
Still not sure why the web platform drops certain words when I post.
Clawfoot tub
Was the old tub, it was a couple inches skinnier
Is a wall hung toilet an option? It will save you 7-9 inches
sorry, I think I go the direction of the toilet wrong. A wall hung may still save you a few inches, but not as many as I said before.
Have you considered moving the door to the left a bit and putting the sink on the right side of the room? As a bonus, this would create the opportunity to give the toilet at least 15 inches of clearance on either side.
I do not love this idea, but could you change the door to open out instead of opening in?
or install a pocket door
i'm not a fan of the pocket door bathroom. i'm always afraid that janky lock will pop open on its own and they always seem to have questionable gaps around them.
all good things take time 😀
two weeks ago- finally finished this and moved in the new tenant the same day0 -
I’d ditch the tub. Ever been on a cruise ship or in Europe? Like others said is probably do toilet/vanity on left wall corner shower on the right.
they even do curbless shower stall with floor drain0 -
what was the problem with prying the stops off the door jam?
the stop wasn’t nailed down, it was a part of the jam.
@GW, thanks for posting your work. Sure wish I could see it.
I have found this happens often… the sight to go to that was/is posted will not open because it did not show in the orange color that other sights open to.
Why is this happening some of the time and not all of the time, and how can I correct this? Does anybody know?
"Orange is the new Black ?" Or vice versa? LOL🙂
Hi @Intplm. , I just had a look at the video. I scrolled over it to copy and then was given the option of opening the link. It worked 🤩
Yours, Larry
1
- 50 Industry Classes
