Reglaze tub
rob51
rob51 Member Posts: 75
We want to reglaze our bathtub.  It has already been glazed once.   Is it recommended to remove the layer of glaze? Or can we deglaze right over that?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,065
    Hi, I'd probably leave the question to whoever is going to do and warrant the job. Perma Ceram is a franchise that might be able to answer the question also. If the glaze you got is more like an epoxy paint than true high temperature glazing, I'd guess it should be completely removed so there is no question about the new coating adhering properly.
    Yours, Larry
    mattmia2 Member Posts: 16,428
    there are also companies that make drop in liners that are molded to the tub, that is another option.
    Larry Weingarten
  • jumper
    jumper Member Posts: 2,522
    Replace tub with acrylic and your wife will be pleased. Liners sound like a good idea.
