Leaking valve on water tank
Or, you can tighten the packing nut. It's located just below the valve handle and surrounds the valve stem. The nut has the flats on it for wrench tightening.
If that doesn't work, repacking the valve as mentioned above would be next. And if that doesnt work, a good quality ball valve should be the replacement.
I looked closer, and there is a splice in the little area (copper tube) right before the valve. Looks like a replacement is necessary. Tried some sealant and it just wouldn’t hold.
I believe the nut is what is split? But have someone coming to check it out.
it’s been making a serious noise for a month now.. sounds like a horn- uggg0
- 50 Industry Classes
