Frost free sillcock rated for continuous use
Another day, another thing I learn. About to pull the trigger on a 12" Woodford frost-free (based on reccos on this forum) I see in the specifications list: "Not rated for continuous use."
After a brief internet rabbit hole I understand that this has to do with the anti-siphon system: these are not rated for continuous pressure.
Any suggestions for a good quality sillcock rated for continuous use?
(As you may have guessed I'm adding a timer based irrigation system for our plants and so will keep the bib/sillcock always on in the summer.)
None that I know of are rated for continuous use. That said, I am currently using mine for temporary drip potted, irrigation. The concern is that the built-in Vacuum Breaker (VB) will, with continued use, and therefore continuous pressure, discharge water from said VB. All of them are designed this way to discharge the back pressure. Also, your local code may not accept the sillcock to be used this way.
Instead, maybe try something like this on a regular hose bib.
You will need to winterize it as it is not "frost-proof." But it should offer a better result.
Maybe just a regular hose bib protected by a RPZ up-stream of it. The hose bib type may spit water every time pressure is applied then removed. It's doing its job.
I'm guessing https://www.supplyhouse.com/Woodford-14CP-12-MH-Model-14-12-1-2-MPT-x-Sweat-Inlet-Wall-Faucet-w-Metal-Handle
(14CP-12-MH) - the 14 series - will work for my application. Would appreciate someone takign another look. There is no vacuum circuit breaker, so there is no 12 h limit.
Yeah, I attach those between the spigot and the hose.
This is all on a timer? Your simplest — and safest — bet is going to be an on/off valve in the building where it won't freeze, then a vacuum breaker, then a line going to the irrigation connection — with another valve out there somewhere which OPENS when the irrigation system is off, to dump pressure from the system.
I saw people on this forum were happy with Prier and I found the C-134 (Diamond) range of products ( ). Not cheap but not outrageous either, made in the USA (made, or assembled? either way …) I briefly considered Bluefin but decided if you all like Prier, I'll go with Prier.
My plan is to replicate what I have now, but with a frost free bib
[ sillcock ] → Y-splitter → (1, 2)
1: backflow preventer → garden hose
2: timer → backflow preventer → irrigation system
(The Y-splitters I have have valves on each branch)
^^^^^^^^^^^^^^^^^^ THIS ^^^^^^^^^^^^^^^^^^^^
But be sure to winterize.
- 120 Geothermal
