What happened to Rems Tools(USA)
young heating guy, what happened to rems? I was looking into learning how to bend copper and fell into the rabbit hole. Stumbled upon rems and their expensive tools. Don’t really see anyone using them today or any guys bending Hard copper like they do in Europe.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,539
    Not sure...but Ridgid makes high quality copper tubing ratchet benders. I have them in 1/2" & 3/4" Work great 👍. Mad Dog
    Jalen_Jalen2006Long Beach Edjpm659er
    EBEBRATT-Ed Member Posts: 20,155
    Rems is still around as far as I know. I have a Rems Amigo electric threader I bought from a guy that retired back in the 90s and its still going
    Jalen_Jalen2006
  • 9326yssh
    9326yssh Member Posts: 46
    edited July 2025
    Those photos look really awesome
    I'm just wondering How is bending vs soldering time wise?
    And isn't the copper getting thinner when you stretch it, like if it was type L wouldn't it be like type M after a stretch?
    hot_rod Member Posts: 27,416
    Ever watch a good electrician bent EMT condiut. Once you get the math down it goes pretty quickly. There are some bending software programs also.
    I doubt it is as fast as press fittings, but faster than sweat copper.
    Yes the outer radius thins and the inner "bunches up", I suppose:)
    I know those return bends on the end on HW and refrigeration coils are very thin copper. They run some pretty high pressures.
    Bending is addressed in the CDA manuals and I believe is accepted in all the plumbing and mechanical codes.
    I have bent some type M, but it tends to pucker up on the inner radius, L works best with plenty of lube.
    I have found that old copper tends to split on the bend, for some reason. Like it hardens on the shelf??
    There is a rep/ wholesaler in Illinois that made hundred of copper tube radiant ceiling grids. They had a home made copper bending tool. They kept the layout drawings of all the jobs, dating back to the 1950's, till recently so they could furnish repair loops!
    Mad Dog_2IronmanPeteAjamplumb
  • 9326yssh
    @hot_rod in the last picture they're all mechanical tee's looks like, I only once saw a guy doing that it took quite a while. So how is that compered to sweat
    This photos really make me think if at all I know what I'm doing, I mean that photo is hydronics at it best
    Thank you
    Jalen_Jalen2006
    Old tubing gets work hardened. I don't know how if it is just sitting but it is a real thing.
    Old tubing flares will split. When you flare old stuff you can heat it to anneal it or flare it a little and back it off flare some more etc with a little oil on the flare cone.
    Same with bending
  • HydronicMike
    HydronicMike Member Posts: 342
    I use the Rothenberger Robend 4000. My buddy, who used to be on here, made a really cool calculator to easily do the math.
    He also showed me how to buy it overseas for about 1/2 the price as you can from Rothenberger USA. The only downside was it took about 3 weeks to come in.
    IronmanAlan (California Radiant) Forbes
    mattmia2 Member Posts: 16,692
    edited July 2025
    I know that copper work hardens. If you ever have tried to use a brass compression ferule that has been sitting around for a few years you will know that they harden over time. I assume the copper work hardens over time as well as with actual work. maybe temp changes are the same as working it.
  • PC7060
    PC7060 Member Posts: 1,794
    edited July 2025
    A large shop could do the layout design in advance and pre bend a lot of the tubing as part of the install kit.
    The RE#MS tee puller is a lot less $$ compared to a T-Drill. This is a T-Drill notch tool, however. Notching a piece of solar absorber tube .
    By code it needs to have two dimples on the stub. One gets silver soldered over, the other is for inspection to assure of the depth. This older tool only does one dimple.
    i have seen an even simplier tee puller that goes into a cordless drill I think Flynnstone posted it somewhere.
    Screenshot 2025-07-28 at 11.13.16 AM.png Screenshot 2025-07-28 at 11.13.04 AM.png Screenshot 2025-07-28 at 11.13.34 AM.png Screenshot 2025-07-28 at 11.12.45 AM.png
    HydronicMikePeteA
  • HydronicMike
    That t drill notch tool is wickedly expensive
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    Why copper hardens. Bending the copper causes
     work hardening (or strain hardening) because working or straining the copper introduces defects, known as dislocations, into the structure. These defects interfere with further deformation, making the copper harder and stronger, thus making it more difficult to bend further.
    Additionally, The processes responsible for the embrittlement of copper are:
    diffusion of hydrogen into the copper /copper oxide matrix
    . reduction of cuprous oxide by hydrogen to produce H20. entrapment of H20 in the crystal structure increasing dislocation density, severely.
    No, I'm not THAT smart. I just know how to do research. :-) And remember, Hydrogen and Oxygen never sleeps… Me? I'm not aging. I'm oxidizing :-) Those aren't wrinkles, they're oxidation marks.
    Field wise, I have seen 40 Y.O. copper that was SO brittle that if you grabbed it with Channelock pliers, it woud easily crush. Crystaline structure. System had been operated at over 200 degrees F for a very long time. Went through the "Turn it up" syndrome. Apartment complex.
    Enjoy!
    ME
    Larry Weingartenjamplumb
  • Robertw
    Robertw Member Posts: 73
    Oh how i remember the days of copper racks with " hard " tubing and " BT" tubing. The wrath of my father if I grabbed bt to do straight runs.
    Robert W.
    Energy Kinetics
    The REMS came with a pair of pliers with a couple prongs to dimple the tube. I lost mine.
    The T-Drill tool cuts the curve profile and puts the dimples in. When you look down the trunk you do not see ant branches protruding in. You do with the REMS tool, however.
    HydronicMike
