I'll Fix It, Honey.
I've been working at a house where the husband is a mathematician/engineer. He was always the one that did the plumbing and electrical repairs in the house. He even did the work to repair any heating system problems. As he got older, fewer things got fixed. Slowly, the Honeywell zone valves stopped working and eventually, there was no heat in the house. The husband is now in a memory care facility and his wife has decided that she wants heat, so she called they only person - still alive - that worked on their system in the past - me.
I've replaced all the zone valves only to find out that none of the thermostats communicate with the controls in the boiler room. I suspect rats chewing through the wiring as they had a longtime vermin problem and I've replaced the old thermostats with Honeywell RedLINK wireless units.
All the old thermostats still work as does the transformer relay. They are so beautiful and I can't bring myself to throw any of them away.
Those are cool thermostats!
The horizontal type with the HG bulbs was in my mother's house from about 1960.
It was branded with the Lennox logo.
Surely a dilemma.
how do rats even get in to that..i guess it is a circulator relay?
I wondered myself.
how was that controlled, was the boiler warm start and the t-stat just controlled the zone valve and the end switch controlled the circulator?
Smart guy, that @mattmia2. They also have a small hotshot indirect up near the ceiling with line voltage through the aquastat in series with the indirect pump.
The boiler is a Peerless 210K BTU; way oversized for a 2,500 sq. ft. house.
gas didn't cost enough for people to care 60 years ago.
is that one heat cool but not labeled R W Y? What is that bottom terminal, I can read C and H which I assume is cool and heat.
Surprised not to see a round Honeywell mercury type!
might be too old
Both always same time and temp. Old one still functional!
It's probably "Y".
The face opens up easily with a metal, pull-out hinge and smooth clips into the base. And no batteries for programming that many of my customers can't figure out. I end up telling them just to put it on "Hold".
Two btu per sq ft for degree difference for a slab1
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
