New refrigerants Epa 608
I've got a universal and no supply house here in the Detroit area has mentioned anything. They just want something on file for your account. 454B here is still in short supply. I paid dearly for a jug just to finish a job. Got one unit with no refrigerant in it when I picked it up. Luckily the supply house just had me bring back the unit and exchange it. Luckily I've got a nice boiler job lined up for a renovation and can take a break from the madness from the new units for a few weeks.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
Like everything else the MFGs don't test as well as they should. I am sure it will be painful until things get sorted out.
Unfortunately the r290 equipment hasnt gotten better. Used to recommend "name brands" like true and bevair, but they fail the same rate as rebranded offshore. Only advantage is we can get the replacement parts with name brand. Lol.
Talking to manufacturer techs, compressors are an issue and evaporators are leaking. Ive done A LOT of evaporators on 1-2 year old equipment. I wonder if it is a refrigerant issue with the copper or a quality issue with the evaporator. As to compressors, the manufacturers are forcing customers to buy new units as compressors are quoted in months, not days; and not cheap either.
Great for the environment, dont build a 30 year cooler, dont fix your 1-5 year old cooler; toss it into the landfill and buy an new cooler that you can replace in 2-3 years. Because the environment and efficiency and #we care.
Should be even more fun coming, hoshizaki says all their small to mid sized ice machines will be r290 in a year or so. Claim its mandated by Uncle Sam. Might as well hook the r290 can to them and change the can every week. 🤷
Unofficial, i hear 134a works well in r290 equipment. 🤦
Yes, your old card is good. But as you might recall when you took your EPA608 test, they mentioned that it would be your responsibility to keep current with new regulations. So, as another responder mentioned, you should study and get familiar with the new refrigerants that are now required as of January 2025. And there no doubt may be newer requirements that come in the future.
@ronaldsauve " But as you might recall when you took your EPA608 test, they mentioned that it would be your responsibility to keep current with new regulations."
I don't remember anything from 1992 LOL🤣
Seems like a big downturn in quality the last few years.
Between microchannel problems, evap. coils leaking and just poor quality. I have had two window units fail and both were less than 4 years old. 1 a GE and the other a Friedrich.
Oh, and the mini split line sets with the white insulation.
Between boiler and AC equipment failing…………how long does equipment last now? The old 20 year standard doesn't seem to hold any more.
The only ones making out is the scrap guys. The customers are taking a hit.
With all the quality problems we were better off with 12 & 22 equipment that didn't leak.
my ~20 year old refrigerator seems to be doing just fine. except for the broken drawers, but that if from me trying to shove too much in them.
pretty sure that has nothing to do with the refrigerant and everything to do with the manufacturing and possibly engineering quality.
what is missing in the regulation is sufficient penalty for your equipment spontaneously losing its charge to be a deterrent. assuming that the our commercial credit laws make it sufficiently hard to just declare bankruptcy and borrow more money to start another company.
Unless you've worked on the equipment you wouldn't understand what I meant.
I'm sure you've experienced what happens in a car with a 134A system when you're stuck in traffic and there's not a ton of airflow through the condenser? R12 systems behaved better under the same conditions.
at that point i'm more concerned about the fan motors using more power than the alternator output at low rpm. other than that, mine seems to work fine as long as it has a fullish charge.
What kinda unreliable old garbage are you driving? 😉
Are there continuing education classes that cover them and would cover card?
If you have your EPA608 type 2 or universal you can work with the new A2L refrigerants. Most manufacturers and wholesalers are doing updates so contractors know the specifics they need to before they get to the jobsite. If you want an official A2L certification and you already have the Type 2 or universal 608 card you can take an open book test and get certified for about $25, you do not need this to work with the new stuff, your EPA608 card is enough
All the supply houses are offering classes on the new refrigerant
2001 325i but as far as i know the output of any automotive alternator plummets at low engine speeds. Might be a 150a alternator at 2000 rpm of the crankshaft but outputs say 30a at idle. You could change the ratio of the sheaves to turn the alternator faster but that causes a number of other problems.
There's always a lot of hate for environmentalists in these threads but do they really cause old refrigerants to get made illegal and replaced with shiny new refrigerants that have the same or sometimes even worse effects on the environment than what they replaced?
I say follow the money.Refrigerant developers like to be patent protected. They don't like refrigerant that is older than a few years because even though a patent is 17 years, a lot of that is taken up by getting it approved and spinning up the manufacturing.
Environmentalists would love a refrigerant that doesn't leak and works great for years. You all know ones that were like that.
But the manufacturers don't like that. They want to have patent protection on their freshly-mandated formulations. And their lobbyists are 100% in place whispering in lawmakers' ears. Then they blame the environmentalists while they collect their $$ on their new formulations. Tell me how I'm wrong, I'll listen.
And of course brand new machinery has to be purchased to use the newly-mandated refrigerants. Don't be fooled into hating environmentalists. I personally don't care about the environment because I don't have any kids, but some of you do.
make us accountable for loss of refrigerant. Done
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
