Radiator removal
Ghynes440
Ghynes440 Member Posts: 61
any tips on how to get this sized part off? I’m removing the radiator in the bathroom to get it completely stripped due to paint chipping off and rusting from being right next to the toilet. I just sprayed some penetrating oil.
    Jamie Hall Member Posts: 27,277
    Your best bit is to hope that the small hex is half of a union — I can't really tell from the photo. If it is, there's a chance you can get it to unscrew from the bushing in the radiator.
    I note that it looks as though someone has been hacking at it with a pipe wrench. A big crescent, adjusted to fit, would be better…
    mattmia2 Member Posts: 16,545
    Looks like whoever changed it to copper screwed a male adapter in to the radiator and sweated it in place, doesn't look like there is a union there.
    PeteA
  • bburd
    bburd Member Posts: 1,296
    You will probably have to cut the pipe to get that radiator out of there. It looks like the copper was sweated in place after that adapter was screwed into the radiator bushing.
    Bburd
  • Ghynes440
    that’s what I was thinking. I was planning on redoing the copper pipes anyway
  • Big Ed_4
    Big Ed_4 Member Posts: 3,523
    That bushing looks like it is counter sunk in the middle , it may be a cast bushing ??
    It may be your lucky day …
    EdTheHeaterMan Member Posts: 12,084
    When you cut the copper elbow with a hacksaw and you remove the other side the same way (if there is no valve or union) you can then add the proper valve and union combination when the radiator returns with your new finish.  Be careful that the paint or other coating is something that is compatible with the temperature you expect the radiator to operate.  There have been folks herein that asked how to stop the odors that are emitted from the paint after it is heated to 180°.  I can't remember what paint the folks used that resulted in that horrible odor, I just remember that the odor was more unbearable as the radiator temperature increased.   Read this: https://www.bestheating.com/info/painting-a-radiator/
    After the radiator is ready to be put back in place, you should invest in the proper Radiator valve and union return bend so that future service will be easily completed by loosening the unions on the valve and return bend.  I believe the links will give you examples of the lower cost 3/4" sweat fittings. There are also more Decorative valves and fittings that you may want to consider if you are so inclined.
    bburdAlan (California Radiant) Forbes
    EBEBRATT-Ed Member Posts: 20,103
    Cut the pipe and move the rad where you can work on it. Lay it down on its front, Put a 2' pipe wrench on the bushing with a cheater pipe and wrench it out. You may need 3 people. One to sit on the radiator and one to help you push the wrench. If it won't come out use a Sawzall to make some slices in the bushing and then pick the pieces out with a cape chisel.
  • Ghynes440
    Thank you for all that info. I am actually getting it powder coated. There is a company that refinishes radiators near me and that is the process . The other side of the does union with a shut off valve, which was easy to get off. Instead of sweating fittings, I plan on renting a copper pipe crimper.
    edited June 2025
    @Ghynes440 said: Thank you for all that info. I am actually getting it powder coated. There is a company that refinishes radiators near me and that is the process . The other side of the does union with a shut off valve, which was easy to get off. Instead of sweating fittings, I plan on renting a copper pipe crimper.
    All good to get copper press fittings that will use a press tool. You should make arrangements to purchase the return bend union. Not sure if that make that in a 3/4" press fitting so you may need to get a 3/4" press x Male adaptor and thread on the 3/4" threaded union bend. Just putting it back as is, with no union, may not be the best idea if you plan on living there for a while.
    delcrossv
  • delcrossv
    delcrossv Member Posts: 2,203
    Replace it with one of these.
    PC7060Alan (California Radiant) ForbesGrallert
  • PC7060
    PC7060 Member Posts: 1,790
    do this^^^^
    Leave the adapter as is and powder coat with radiator.
    hot_rod Member Posts: 27,352
    Is the bushing leaking on the large thread? If so that will probably involve cutting it out.
    PC7060
  • RTW
    RTW Member Posts: 285
    Notwithstanding the good expert advice thus far, some projects are Not DIY and best left to a qualified steam heating expert - even a pipe fitter may be an option. I removed over ten cast iron radiators for paint removal ( it was called soda blasting ) and used a ferrous metal paint to re-coat . That was 20 years ago and worked fine to date.
    My cast iron radiator connections were basically fine, though some did drip water now and then. The fix was to apply an ever-so-thin coat of pipe dope when reconnected that ended that issue
    Im thinking those parts must be salvaged - its not like you can go anywhere to get a replacement part on a 75 year old, or older, steam radiator connection
    All the best,
    RTW
